LVDS IO error
mode
Hi, again
I try very simple case as attached.
But It is same error result.
Please advice how to interface lvds IO input by primitives
SreekumarR_G_Intel
Can you give me the device part number ? Did you check the clk1(n) is connected to the clk_n pin of the device ?
Thank you ,
Sree
mode
FPGA Part number is EP4CE15F17C8N (Cyclone iV)
However i find the reason that is naming of negative pin.
Whenever define one of differential pin, tool generate name(n) automatically.
After that i annotate back it to Design PIN.
This is error happen.
Can you teach me how to process differential PIN define correctly?
David
SreekumarR_G_Intel
There are many ways you can do ; usually way i do is assign the signal I/O standard as "LVDS " and assign the xxx_p pin in the pin planner or assignment editor or qsf assignment, then xxx_n will automatically assign by the tool .
Hope helps ;
Thank you,
Sree
