17264 Discussions
LVDS PIN define and ALT_input_diff error
mode
I define IO PIN and I use ALT_INBUF_DIFF
After compile error message as below;
Error (275021): Illegal wire or bus name "CAM_CP(n)" of type pin
How fix this problem?
David
Vicky1
I am not clear whether you get this Error in rtl or after pin planner.
I would like to suggest you check the below details,
https://forums.intel.com/s/question/0D50P00003yyNpESAU/altinbufdiff-and-pin-planner
In pin planner, assign the pin only to the positive pin of a differential pair, (n) pin will get assigned automatically by tool.
Refer the 'Assigning Differential Pins 'from link below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii52013.pdf
Vicky
mode
Hi, Thanks for your email. However I try very simple case as attached. But It is same error result. Please advice . Thanks David
Vicky1
Hi David,
'However I try very simple case as attached.' - - - - where?
could you please provide the project(*.qar) file (Project menu->Archive Project..) for replication purpose?
Vicky
mode
Hello, I send capture files Thanks David
Vicky1
Hi David,
I am unable to see your capture files, Can you?
'could you please provide the project(*.qar) file (Project menu->Archive Project..) for replication purpose?' ------ if possible.
Vicky
Vicky1
Hi David,
would you like to provide files or should I consider that case to be closed?
Vicky
