17249 Discussions
Length Correlation in VHDL
i have here a programme that calculate the correlation of data bits with 8 bits as length in this case i will need for the calculation 4 stage the figure explain the program , so i want to do it with variable length 16 or n for length so can you help plz
Thank you in advance for you reponse
library ieee;use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity correla4bit is port ( clk : in std_logic ; rst : in std_logic ; data: in std_logic_vector(11 downto 0) ; code: in std_logic_vector(15 downto 0 ) ; Q :out std_logic_vector(17 downto 0) ) ; end entity ; architecture arch of correla4bit is type RAM is array (0 to 3) of std_logic_vector(3 downto 0) ; type ram16 is array (0 to 3) of signed(15 downto 0) ; type Rom is array (0 to 3) of signed(11 downto 0) ; signal voie :Rom ; signal CD : RAM; signal temp: ram16; signal sum0 :signed (16 downto 0) ; signal sum1 :signed (16 downto 0) ; signal AB :signed (17 downto 0) ; begin CD(0) <= code(15 downto 12); CD(1) <= code(11 downto 8); CD(2) <= code(7 downto 4); CD(3) <= code(3 downto 0); etalement:process(clk,rst) begin if(rst='1') then Q <=(others=>'0'); temp(0)<=x"0000"; temp(1)<=x"0000"; temp(2)<=x"0000"; temp(3)<=x"0000"; elsif(clk'event and clk ='1') then voie(0)<=signed(data) ; voie(1)<=voie(0); voie(2)<=voie(1); voie(3)<=voie(2); for i in 0 to 3 loop temp(i) <= voie(i)*signed(CD(i)); end loop ; sum0<= resize(temp(0),17)+temp(1) ; sum1<= resize(temp(2),17)+temp(3) ; AB<=resize(sum0,18)+sum1 ; Q<=std_logic_vector(AB) ; end if ; end process ; end architecture ;
This is just a standard N tap FIR.
First of all, I suggest you bring in all C co-efficients separately, not as a single bus.
Second, for N taps, you will probably need a package to create the array types to make the design generic.
I dont know why you have declared RAM and ROM types - there is no RAM or ROM in your drawings. They are just arrays of registers.
I would also suggest putting registers after each multiplier and adder stage, or the fmax is going to be very low.
