Library in QSYS
Hello everybody,
I've got a bit silly question about using QSYS.
I usually work with several libraries. Each library contains a top representing an IP (such as, for example, MedianFilter IP in medianfilter_lib, UART IP in uart_lib, ...)
When I use QSYS to integrate this IP, the .QIP file generated by QSYS mentionned for all IP 'lib_system' as the requested library... but in my cases, it is either medianfilter_lib, ...
The result is that the analysis&elaboration process in Quartus fails (design library medianfilter_lib does not contain primary unit medianfilter_top).
Do you have any workaround?
Many thanks!
In the _hw.tcl file add the libraries, eg., here's the files I need for my SRAM controller:
add_file ../../packages/src/utilities_pkg.vhd {SYNTHESIS SIMULATION} add_file ../../packages/src/altera_avalon_pkg.vhd {SYNTHESIS SIMULATION} add_file ../src/avs_sram_fsm.vhd {SYNTHESIS SIMULATION} add_file ../src/avs_sram.vhd {SYNTHESIS SIMULATION}
I suspect that your problem is you have added only the source for your component, and have not listed the libraries it uses.
Cheers,
Dave
I absolutely agree with you but how do you associate a module (or a file) with a library that will be used in the .QIP file generated by QSYS in such a way that you will have:
set_global_assignment -name VHDL_FILE -library sdramcontroller_lib
and not
set_global_assignment -name VHDL_FILE -library lib_system
--- Quote Start ---
I absolutely agree with you but how do you associate a module (or a file) with a library ...
--- Quote End ---
Hmm, good question.
I haven't used Qsys a great deal. However, in SOPC builder I found that VHDL libraries were not well supported. I just looked at the add_file documentation, and it does not have an option for the library in which to compile it.
I also found that the automatically generated instances always missed the lines:
Library mylib;
using mylib.mycomponent.all;
So I resorted to using the callbacks to create my own top-level instances. Quartus does not complain about these missing library calls, but Modelsim does.
I'm not sure if this 'feature' has been carried through to Qsys.
Cheers,
Dave
i've found Quartus VHDL library support to be poor in general
Ok, many thanks for your 2 answers...
I found a solution:
I use a .QIP file so as to list all requested VHDL files
My new _HW.tcl:
... add_file module_name.qip {SYNTHESIS SIMULATION} ...I create a module_name.qip file:
set_global_assignment -name VHDL_FILE -library common_lib set_global_assignment -name VHDL_FILE -library module_lib set_global_assignment -name VHDL_FILE -library module_lib set_global_assignment -name VHDL_FILE -library module_lib
Just wanted to mention that I had strange problems with Analysis&Synthesis of a project with a generated Qsys component, and I believe my problems could be attributed to the library handling as well.
For a Qsys custom component, I had stuff defined in a package (which is often necessary, with no workaround) and accessing packages need explicit library specification (use work.mypackage; etc). This usually works fine (for some reason, Quartus still finds the package althogh the generated Qsys system will place all units in a specific Qsys library), but I had one persistent error were something went wrong. It turned out that Analysis&Synthesis was unable to call a function in the custom package (the function was used to provide the actual for a generic).
I finally could work-around this by declaring a constant in the package, initializing the constant with the function (in the same pakcage), and provide the actual from that constant. In this way Analysis&Synthesis called the package function during package elaboration, not when elaborating the entity that needed the value.
My suspicion that this was a VHDL library issue is strengthen by the fact that instantiating the component directly in the Quartus project, rather than have it generated by Qsys, worked fine.
