17251 Discussions
Line out port de1 .. help !
Hi all ..
my project is alarm clock ..
and i'm going to write the code using Verilog code but one thing that i don't know how to use it :(
the LineOut port on altera DE1
how can i write the code to get sound when the alarm done?
and can de1 generate sounds?? or i must line in sound to get it out ?
any one can help me with that?
I'm pretty sure that's the point of the class..
Learning verilog. And figuring out how to talk to the hardware..
I haven't looked at the DE1 lately, but there should be a codec between the FPGA and line-out. First dig up the datasheet for that part, and figure out how to send data to it.. (Most likely an I2S interface)
Then write the verilog code to send some 1-KHz to 5 KHz tone tone to the CODEC, for Line-out.
If you can make it make a tone, you can then work on the alarm clock portion.
Pete
