17253 Discussions
Linux Quartus Pro Edition quits unexpectecly because of jspice model library
Rutherther
Hello, I am getting an error when compiling a design for Intel Cyclone 10 GX using Quartus Pro Edition on Linux. It crashes on Fitter > Place stage at 99 %.
I tried looking for a jspice model library, but found nothing that looked useful. Any idea what the problem could be?
I've installed the software using individual files, I have the base Quartus installed + Intel Cyclone GX and Intel Arria 10 device support. I've also installed questa, high level synthesis and Intel FPGA SDK for OpenCL in the hopes of resolving the error. I was thinking that there may be a jspice library in one of these.
Problem Details
Error:
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_nightfury_buffer_netlist_builder.cpp, Line: 212
Could not load jspice model library
Stack Trace:
  Quartus         0x10959b: SIN_NIGHTFURY_BUFFER_NETLIST_BUILDER::load_simulation_models() + 0x81b (tsm_sin)
  Quartus         0x13398b: SIN_NIGHTFURY_SIMULATION_INTERFACE::allocate_buffer_builder() + 0x1b (tsm_sin)
  Quartus          0x935a7: SIN_DB_MANAGER_BODY::initialize_managers(SIN_PROCESS_MODEL*) + 0x57 (tsm_sin)
  Quartus          0x94bc9: SIN_DB_MANAGER_BODY::run_simulations(CDB_ATOM_NETLIST const*, SIN_PROCESS_MODEL*) + 0x69 (tsm_sin)
  Quartus         0x1ccdea: PTI_AIOT_CALCULATOR::run_aiot_simulations() + 0xca (tsm_pti)
  Quartus         0x1b969d: PTI_CELL_ANNOTATOR::run_aiot_simulations() + 0x2d (tsm_pti)
  Quartus         0x16bee0: PTI_DELAY_ANNOTATOR::full_annotate_routing_and_cell(std::vector<CDB_ATOM_NODE*, std::allocator<CDB_ATOM_NODE*> > const&, PTI_ROUTING_ANNOTATOR&, PTI_CELL_ANNOTATOR&, bool) + 0x6c0 (tsm_pti)
  Quartus         0x173b78: PTI_DELAY_ANNOTATOR::build_multicorner(PTI_DELAY_ANNOTATOR::INVOKE_MODE, bool, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> > const&, bool) + 0x8f8 (tsm_pti)
  Quartus         0x11f6f2: FITCC_TDC_UTILITY::initialize_dat(TDC_ACCESSORIES::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> > const&, bool, bool, bool, QGL::FOREST<int, int>*, bool, bool) + 0x842 (fitter_fitcc)
  Quartus         0x1223ca: FITCC_TDC_UTILITY::setup_tdc_utility(TDC_ACCESSORIES::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> >, bool, bool, bool, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool, bool, bool) + 0x91a (fitter_fitcc)
  Quartus         0x122e87: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY(FITCC_ENV const*, TDC_ACCESSORIES::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> >, bool, bool, bool, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool, bool, bool) + 0x257 (fitter_fitcc)
  Quartus          0xcefd7: FITCC_ENV::get_tdc_utility_or_create_if_necessary(FITCC_ENV::FITCC_TDC_UTILITY_REQUEST_TYPE, TDC_ACCESSORIES::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> >, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool, bool) + 0x817 (fitter_fitcc)
  Quartus         0x5dd7e2: vpr_qi_change_default_dat_to_all_corners() + 0x1e2 (fitter_vpr20kmain)
  Quartus         0x6c81db: aa_flow_place(FIT::STATE&, PLACER_MODE) + 0x74b (fitter_vpr20kmain)
  Quartus         0x5d0c8d: (anonymous namespace)::place_internal(FIT::STATE&, PLACER_MODE) + 0x5d (fitter_vpr20kmain)
  Quartus          0xa3df1: VPR_QI_FACADE::place(FIT::STATE&) [clone .cold] + 0xe3 (fitter_vpr20kmain)
  Quartus         0x11934b: FDRGN_EXPERT::run_place_flow(QTL::OPAQUE_PTR<PCA::DEVICE_DATA, void (*)(PCA::DEVICE_DATA*)>) + 0x158b (fitter_fdrgn)
  Quartus         0x119cad: FDRGN_EXPERT::run_place(QTL::OPAQUE_PTR<PCA::DEVICE_DATA, void (*)(PCA::DEVICE_DATA*)>) + 0x20d (fitter_fdrgn)
  Quartus         0x11a37a: FDRGN_EXPERT::place() + 0x5fa (fitter_fdrgn)
  Quartus          0x3b589: fit2_fit_place_auto + 0xda (comp_fit2)
  Quartus          0x50fb7: TclNRRunCallbacks + 0x47 (tcl8.6)
  Quartus          0x2985b: fit2_fit_place + 0x2bf (comp_fit2)
  Quartus          0x527df: TclEvalEx + 0x94f (tcl8.6)
  Quartus          0xfa3a6: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
  Quartus          0xfa4be: Tcl_EvalFile + 0x2e (tcl8.6)
  Quartus          0x2a93e: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3de (comp_qexe)
  Quartus          0x2dda6: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x4c2 (comp_qexe)
  Quartus          0x2eeae: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x66e (comp_qexe)
  Quartus          0x6ea03: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x9c (comp_qcu)
  Quartus          0x6ee4a: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x33e (comp_qcu)
  Quartus          0x34275: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xbc7 (comp_qexe)
  Quartus         0x40adac: qfit2_main(int, char const**) + 0x8c (quartus_fit)
  Quartus          0x4e5c0: msg_main_thread(void*) + 0x10 (ccl_msg)
  Quartus          0x50b07: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
  Quartus          0x1f568: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)
  Quartus          0x10f58: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
  Quartus           0xba55: thr_thread_wrapper + 0x15 (ccl_thr)
  Quartus          0x4f6f4: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd3 (ccl_msg)
  System           0x23850: (c)
  System           0x2390a: __libc_start_main + 0x8a (c)
  Quartus         0x4062e9: _start + 0x29 (quartus_fit)
End-trace
Executable: quartus
Comment:
Compiling any project for Intel Cyclone 10 GX using Pro edition ends up in this error, when Fitter > Place stage is at 99 %.
System Information
Platform: linux64
OS name: Arch Linux
OS version:
Quartus Prime Information
Address bits: 64
Version: 23.1.0
Build: 115
Edition: Pro Edition
SyafieqS
Internal error most of the time might be due to tool issue.
I need to check the issue, thus is it possible for you to attach the design in qar?
Rutherther
That's not a problem at all. The compilation crashes for every project in Quartus Prime Pro (without license, only Cyclone 10 GX support). So I am including a simple project that contains just an AND gate connected to two inputs and one output.
SyafieqS
Thanks. I am looking into this to replicate at my end.
SyafieqS
Hi Ruth,
I am not able to see the issue using the design.
Just for sanity check, can you reinstall Quartus?
Just to make sure everything is setup properly.
SyafieqS
Let me know if there is any update
Rutherther
yes, I have an update from today. It took me a few days to download all of the components as I don't posses that fast internet connection and the files are large.
I have downloaded installation from tab called Multiple Files instead of Individual Files like last time, just to change something if there was a problem. After installation, it is working correctly.
So this has been solved. I am not sure whether the problem was in the individual files or just something went wrong in the installation process.
PS: When I install only Quartus with Cyclone 10 GX support, when compiling, I get an error and I have to install Aria 10 support to resolve it. This happened to me on two separate computers, once Windows and once Linux.
SyafieqS
Glad that had been resolved. Let me know if there is any other concern at your end.
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
