17255 Discussions
Doubts regarding altddio_in ip,
Sameer-sahu
Hi all,
iam trying to run a test bench on the ip 'altddio_in', here i have used 8bit altddio_in ip
for the input data (data is available in both rising and falling edges), we are supposed to get rising edge data in 'data_out_h' and  falling edge data in 'data_out_l', but iam getting same data as output for both falling and rising edge. Please see the attached image for a better idea. Thanks in advance for anyone willing to take a look.
sstrell
Can you provide the testbench and design code?  No way to tell what's going on here without seeing the design.
Sameer-sahu
SyafieqS
Is it possible to attach the snippet of your tb?
SyafieqS
Noted. Let me know if there is any other concern on this.
SyafieqS
I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
