17267 Discussions
Loading IP-blocks from IP folder doesn't work
Hi, I have a 4 software IP-blocks that I want to be installed under /drivers i the Nios II Software Build Tools for Eclipse.
From my instructor I got an IP-folder containing 3 Ip-blocks: BeMicro_Max_SDRAM folder, BeMicro_VGA_IP folder, and TIMER_HW_IP folder and their .h-files are put by the tool after project set up into /drivers.
But my own IP-block VGA_UTIL_IP is not installed by the tool. Two things happens:
i. It refuses to create the project completely, giving me the error message
SEVERE: File not found "C:\Users\root\Documents\Ceng_100\Konstruktionsdokument\ip\VGA_UTIL_IP\HAL\inc\altera_avalon_timer_regs.h".
SEVERE: nios2-bsp-create-settings failed.
Here is what bothers me: VGA_UTIL_IP does not use altera_avalon_timer_regs.h, only TIMER_HW_IP uses it.
ii. If I add altera_avalon_timer_regs.h to HAL/inc,just to get rid of the error message, the project is generated but the tool does not put my vga_util.h in /drivers/inc nor the vga_util.c in /drivers/src
The name of my folder is VGA_UTIL_IP, and the tcl script is named VGA_UTIL_IP_sw.tcl and looks like this:
create_driver VGA_UTIL_IP
set_sw_property hw_class_name VGA_UTIL_IP
set_sw_property version 1
set_sw_property min_compatible_hw_version 1.0
set_sw_property bsp_subdirectory drivers
add_sw_property include_source HAL/inc/vga_util.h
add_sw_property c_source HAL/src/vga_util.c
add_sw_property supported_bsp_type HAL
Why does this not work?:confused::confused::confused:
I am doing an include of an .h-file found from my instructors ip, in my ip# include <BeMicro_VGA_IP_Driver.h>
Could it be that when the tool is interpretating my tcl-script it searches for that .h-file above, doesn't find it, and points the error message in wrong direction, so to speak?
Greateful for some help
/laskar01
