17249 Discussions
LogicLock regions in source control - possible?
I'm having a ****ens of a time trying to figure out how to put logiclock regions into source control.
I thought that all the needed LogicLock info was saved in the QSF file, but it seems there is some magic stored somewhere in the db subdirectory. Here's why:
I start with a clean slate, then get the just the source files (no LogicLock regions yet) for my design, including the QSF.
Next, I add LogicLock regions (locked and fixed). Compile. I note that now there is info in the QSF that describes them.
Next, I delete the db directory and compile again (the QSF still has all the LogicLock info in it). The compiler throws up a bunch of warnings similar to: "Warning: One or more LogicLock region membership assignments are unused
Warning: "FastRxEngine:inst8" in region "FastRxEngine:inst8""
What am I missing? The reason this is important is there are several people working on this one project, and we each compile from source files on our own computers. Surely I can't be the only one who'd run into this. Thanks -
-Dano-
I'm not sure what's going wrong, but I compile projects with LLR info in the .qsf and no /db, and it works all the time. You definitely should not need anything else, but I really don't know why that would occur.
