Matlab to VEEK
I recently purchased VEEK for my final year project on image processing. I previously done the algorithm on MATLAB. Is that anyway to use this code or convert it to compatible in VEEK(DE2 115)?
If you designed your algorithm in Matlab Simulink then you could possibly replace the standard Simulink blocks with Altera DSP Builder blocks. Otherwise, am not aware of the existence of a Matlab to VHDL converter.
Mathworks HDL coder can probably do that : http://www.mathworks.fr/products/hdl-coder/description1.html
I don't know the tool (only use DSP Builder).
