17250 Discussions
Megafunction ALTPLL simulation Problem
Dear all,
Please help me with this issue:
I want to simulate Megafunction ALTPLL in ModelSim,
The result of ModelSim compilation is no Error, but the output is High Z
The waveform is shown in attached file "PLL_waveform.jpg".
(1)The Resolution of Modelsim is set to ps.
(2)altera_mf.v and 220model.v are included.
Would you please give me a hint or a direction to debug this?
Thank you in advance!
Best Wishes,
William
did you search the log for warnings? i would look for a component not bound to start
which family of ModelSim are you using (AE/SE)?
Hello thepancake,
Thank you for responding.
I didn't see any warnings about PLL or megafunction.
Best Wishes
hi,
I go the same problem too. using the DE0-Nano board and follow the ALTPLL and Mux design in the baord user guide. when doing the Modelsim RTL simulation with lpm_ver and altera_mf_ver included, the C0 output just get hiZ. any advice?
I convert the bdf to verilog format before using nativelink to trigger the modelsim-altera simulator. the C0 output just show hiZ. dont know why? I attached my project design file here, pls help.
