17268 Discussions
Modelsim: add precompiled library
Hi all,
in my project, I need to include a library, MF_pllpack.all:
library ieee;
use ieee.std_logic_1164.all;
use std.textio.all;
use work.mf_pllpack.all;
I have compiled that library elsewhere in another folder.
How can I carry that compiled library under "Work" to use it in my project?
Thanks to all
it's easiest just to compile it for the local work libarary.
vcom the_directory_of_the_MF_pllpack/MF_pllpack.vhd
otherwise you have to import it as an external (not work) library
i have not got the .vhd file (MF_pllpack.vhd), but only the compiling folder containing the compilation files
in that case either:
copy the compiled files to the local work folder and try a refresh
use the ML_pllpack folder as the work folder.
map an external library to the MF_pllpack work folder:
vmap MF_Lib MF_directory/work
and then in your source:
library MF_Lib;
use MF_Lib.MF_pllpack.all;
use the ml_pllpack folder as the work folder.???
I have to include even other libraries...I have to mantain 'WORK' as work folder
then I suggest you do not include MF_pllpack in the work library but map to it as another library.
vmap MF_lib directory_of_MF/work/
then in the code, instead of
use work.MF_pllpack.all;
write:
library MF_Lib;
