17268 Discussions
Megawizard Crash - Creating FIFO
Hi Guys,
Extremely frustrated here. If anyone can help i would greatly appreciate it.
The megawizard crashes whenever i try to create the FIFO megafunction, regardless of settings; even with default no change.
By crash i mean, it stops responding, windows says "mega_ramq.exe stopped working". Screen shot attached.
i swear it happened with some others aswell, but can't seem to repeat on others atm.
what i've tried
1. Occurs in Qaurtus 11.
2. Tried using 10.1 that was still installed. Probem remained.
3. Uninstalled all altera products.
4. Re-installed 11. Probem remained.
5. Uninstalled 11.
6. Re-installed 10.1. Probem remained.
7. Googled the sh*t out of it and come up with nothing.
8. Sifted through the altera KB. nothing
my system
Win7 x64
Web editions of quartus.
Spam aside. For the moment i'm just creating with 9.1 and will try import it
i'm using Subscription Edition 11.0 on Windows 7 64-bit and i can generate a FIFO without a problem
do you have all of the device families installed?
--- Quote Start ---
--- Quote End ---
I have the same problem under ubuntu or Centos, it happens with me for quartus10 version !!!! I was just going to create a thread about this issue !!
Thanks for reply boys.
Thanks pancake, i'm running the web edition, perhaps thats the problem. I've logged a ticket with altera, but who knows what that will do if anything.
I disabled the visual effects in ubuntu and it worked well
--- Quote Start ---
--- Quote End ---
Having the same problem here, ever since I installed 11 (and then 11sp1 clean install). Still works fine in 9.1. Clean install of 11sp1 on a different machine works fine.
Haven't been able to figure out what's wrong, please post a followup if you make any progress on this.
I met this issue with linux version.
solved with using 64 bit quartus..
I had to format my PC. Annoying
I have the same problem.
I,m using windows 7 64 bit and Quartus II 11.1 Web Edition (32-Bit).
in safe mode (by pressing f8 key befor windows starting), this problem will be solved
In safe mode it is possible to created a FIFO mega function and add to the project and come back to normal window and running the project.
Thanks everybody.
