17263 Discussions
Memory Error in VHDL compilation Altera II
i am using the cyclone III Altera with Quartus II and my system specifications are 1 GB RAM, 500 GB Hard disk and Intel dual core processor, i am trying to implement Smwedly model of power converter, the error i am facing is
" error: quartus ii fitter was unsuccessful. 2 errors, 17 warnings
Info: Allocated 151 megabytes of memory during processing
Error: Processing ended: Fri July 05 20:31:32 2013
Error: Elapsed time: 00:00:10
error: quartus ii full compilation was unsuccessful. 2 errors, 17 warnings" "
i am seeking guidelines about the error i am facing is that the ram ?
please guide
azhar[/I][/I]
The actual errors are in the compilation report somewhere above the "2 errors" line.
Thank you very much for help , i am actually beginner so it is quite confusing for me, i am pasting the Error again following in order to seek help
Info: Found 2 design units, including 1 entities, in source file latchSR.vhd
Info: Found design unit 1: latchSR-rtl
Info: Found entity 1: latchSR
error (10430): VHDL Primary Unit Declaration error at modulatore30aprile.vhd(devil): primary unit "modulatore30aprile" already exists in library "work"
Info (10499): VHDL information at azhar.vhd(devil): object "modulatore30aprile" is declared here
Info: Found 0 design units, including 0 entities, in source file modulatore30aprile.vhd
Info: Found 2 design units, including 1 entities, in source file modulatore30apriletest.vhd
Info: Found design unit 1: modulatore30apriletest-architettura1
Info: Found entity 1: modulatore30apriletest
Error (10430): VHDL Primary Unit Declaration error at modulatore_finale.vhd(devil): primary unit "modulatore_finale" already exists in library "work"Info: Found 2 design units, including 1 entities, in source file sel_shift.vhd
Info: Found design unit 1: sel_shift-scalamento
Info: Found entity 1: sel_shift
Info: Found 2 design units, including 0 entities, in source file sine_package.vhd
Info: Found design unit 1: sine_package
Info: Found design unit 2: sine_package-body
Info: Found 2 design units, including 1 entities, in source file sine_wave.vhd
Info: Found design unit 1: sine_wave-arch1
Info: Found entity 1: sine_wave
Info: Found 2 design units, including 1 entities, in source file sinewavecomplex.vhd
Info: Found design unit 1: sinewavecomplex-arch11
Info: Found entity 1: sinewavecomplex
Info: Found 2 design units, including 1 entities, in source file Vhdl2.vhd
Info: Found design unit 1: vhdl2-rtl
Info: Found entity 1: vhdl2
error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Processing ended: Mon Jul 08 15:31:40 2013
Error: Elapsed time: 00:00:02
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings
can you please help?
HI,
Thank you very much for help , basically i am beginner so it is quite confusing for me, i am pasting the Error again following in order to seek help
Error (10430): VHDL Primary Unit Declaration error at modulatore30aprile.vhd(devil): primary unit "modulatore30aprile" already exists in library "work"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
could you please help?
