17267 Discussions
Memory Initialization File for multiple RAMs
I'm new to FPGA development and maybe this question is simple, but I couldn't find an answer yet.
I am developing a system with multiple M4K memories which are instatiated inside a generate block over a genvar loop (I'm using Verilog and a Stratix II). For simulation I need them to be initialized with different data. I can specifiy a Memory Initialization File in the MegaWizard but this will initialize all memories with the same data. Is there an easy way to specify a different .mif for each memory?
yes, slightly edit the generated file, and add a parameter to it.
Then assign a different string to that parameter each time you instanciate it in the for loop.
Thanks amilcar, how do I assign the parameter within the code?
after the memory instantiation add:
defparam ram_inst.altsyncram_component.init_file = "your_file_here.mif";
Ok I got it so far. I am using the M4K memory within an other design unit. Here is the simplified code:
module LocalMem(...); parameter cpuid = 0; M4K memory ( .clock(clk), .data(m4k_data), .rdaddress(m4k_rdaddress), .wraddress(m4k_wraddress), .wren(m4k_wren), .q(m4k_q) ); defparam memory.altsyncram_component.init_file = {"mem", cpuid, ".mif"}; endmodule module TestLocalMem(...); LocalMem# (.cpuid(1)) localmem_inst(...); endmoduleThis does not work. Within the defparam line, cpuid seems to be empty. No matter what I set cpuid to, the file "mem.mif" gets loaded. I have also tried this to make cpuid the correct ASCII value:
defparam memory.altsyncram_component.init_file = {"mem", 8'd48 + cpuid, ".mif"};but no change...
Maybe you have another hint for me?
I found a solution :)
In case someone has the same problem here is my solution:
To have a parameter concatenated with a string, it needs to represent the number's ASCII value. Therefore 48 needs to be added to its value. An other thing has to be considered: all chars in a string are represented as 8-bit numbers, therefore the parameter has to be 8 bits wide:
parameter cpuid = 0;and
defparam memory.altsyncram_component.init_file = {"mem", 8'd48 + cpuid, ".mif"};fixed my problem :)
