Memory mapped IO query
I have regular ROM & RAM working via altsyncram and now I'm trying to build some memory-mapped IO for my hobby CPU/SoC.
The MMIO code is pretty simple:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; library work; use work.CPU_Definitions.all; -- SUBTYPE OpData_Type is natural range 0 to 2**RAM_WIDTH-1; -- actually defined in my definitions package entity MMIO is PORT ( signal clock : IN std_logic; signal MMIO_address : IN natural; signal MMIO_data_in : IN OPDATA_TYPE; signal MMIO_data_out : OUT OPDATA_TYPE; signal MMIO_wren : IN std_logic ); end entity MMIO; architecture behaviour of MMIO is CONSTANT num_MMIO_BYTES : natural := 2; TYPE MMIO_Type is array (0 to num_MMIO_BYTES-1) of std_logic_vector(7 downto 0); signal MMIO_array : MMIO_Type; -- this is mapped to physical pins in my top entity. begin MMIO_process: process(clock) begin if rising_edge(clock) then if MMIO_wren = '1' then assert false report "writing "&integer'IMAGE(MMIO_data_in)&" to MMIO_address "&integer'IMAGE(MMIO_address) severity WARNING; MMIO_array(MMIO_address) <= std_LOGIC_VECTOR(to_unsigned(MMIO_data_in, MMIO_array(MMIO_address)'length)); else MMIO_data_out <= to_integer(unsigned (MMIO_array(MMIO_address))); end if; end if; end process MMIO_process; end architecture behaviour;
When I simulate this, I see the correct data and address being passed into this process, and MMIO_wren is high. I've confirmed this with an assert statement. All values are within allowed parameters (address=1, data=0x55). However, the value is never stored in the actual array element and I can't see why. Furthermore, at the top level, I get warnings that the pins are forced to ground.
Any advice would be appreciated.
Mark
