quartus error
on cyclon IV E EP4CE115F29C7
i have a ddr controller module connected to altera internal ram. during compilation i get this:
Error: Memory block iliamemory:inst4|altsyncram:altsyncram_component|altsyncram_joj2:auto_generated|ram_block1a15 uses a global signal on its clock-enable1 port. This is not allowed for this family.
it just drives me nuts! my memory megafunction does not contain any clock-enable port. i just have a clock generated from pll and that clock goes into DDR controller aswell as in my altera RAM. when i double click the error it takes me here:
ram_block1a15 : cycloneive_ram_block
WITH (
CLK0_CORE_CLOCK_ENABLE = "none",
CLK0_INPUT_CLOCK_ENABLE = "none",
CONNECTIVITY_CHECKING = "OFF",
LOGICAL_RAM_NAME = "ALTSYNCRAM",
MIXED_PORT_FEED_THROUGH_MODE = "dont_care",
OPERATION_MODE = "bidir_dual_port",
PORT_A_ADDRESS_WIDTH = 9,
PORT_A_DATA_OUT_CLEAR = "none",
PORT_A_DATA_WIDTH = 1,
PORT_A_FIRST_ADDRESS = 0,
PORT_A_FIRST_BIT_NUMBER = 15,
PORT_A_LAST_ADDRESS = 511,
PORT_A_LOGICAL_RAM_DEPTH = 512,
PORT_A_LOGICAL_RAM_WIDTH = 32,
PORT_A_READ_DURING_WRITE_MODE = "new_data_with_nbe_read",
PORT_B_ADDRESS_CLOCK = "clock0",
PORT_B_ADDRESS_WIDTH = 9,
PORT_B_DATA_IN_CLOCK = "clock0",
PORT_B_DATA_OUT_CLEAR = "none",
PORT_B_DATA_WIDTH = 1,
PORT_B_FIRST_ADDRESS = 0,
PORT_B_FIRST_BIT_NUMBER = 15,
PORT_B_LAST_ADDRESS = 511,
PORT_B_LOGICAL_RAM_DEPTH = 512,
PORT_B_LOGICAL_RAM_WIDTH = 32,
PORT_B_READ_DURING_WRITE_MODE = "new_data_with_nbe_read",
PORT_B_READ_ENABLE_CLOCK = "clock0",
PORT_B_WRITE_ENABLE_CLOCK = "clock0",
POWER_UP_UNINITIALIZED = "false",
RAM_BLOCK_TYPE = "M9K"
one strange thing.. if i delete pll generated clock on the ddr controller. and connect it to a input port, then it compiles with no errors. what can i do? tried everything... 3 days iv been wrestling with this misterious error.
This looks like you have a signal declared in a package. You are not allowed to do that for synthesis.
a signal declared in a package???? could you describe what does that means? what is a package? or direct me where can i read about this? the DDR controller is written in AHDL may that be a couse for the error?
