17249 Discussions
Missing clock assignment warning
in a Cylone V SOC project under Quartus 14.0 I get the following message from the Linker:
Warning (332060): Node: clk50a was determined to be a clock but was found without an associated clock assignment.
The Project contains a .sdc file with the following constraint:
create_clock -name {clk50a} -period 20.000 -waveform { 0.000 10.000 }
Any idea what I forgot to do?
Try:
create_clock -name {clk50a} -period 20.000 -waveform { 0.000 10.000 } [get_ports {clk50a}]
Otherwise you create a clock named clk50a to be used for timing analysis, but you don't bind it to any physical signal.
To be clearer, in general you define
create_clock -name {myclk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {clk50a}]
and then use myclk to analyze this clock net.
Thank you, Cris72.
It works, the message doesn't appear any more.
