in a Cylone V SOC project under Quartus 14.0 I get the following message from the Linker: Warning (332060): Node: clk50a was determined to be a clock but was found without an associated clock assignment. The Project contains a .sdc file with the following constraint: create_clock -name {clk50a} -period 20.000 -waveform { 0.000 10.000 } Any idea what I forgot to do?Link Copied
Try:
create_clock -name {clk50a} -period 20.000 -waveform { 0.000 10.000 } [get_ports {clk50a}] Otherwise you create a clock named clk50a to be used for timing analysis, but you don't bind it to any physical signal. To be clearer, in general you define create_clock -name {myclk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {clk50a}] and then use myclk to analyze this clock net.- Mark as New
Thank you, Cris72.
It works, the message doesn't appear any more.
