Missing .sof
We have several projects all using Quartus II V7.1Build 178 (SP1).
For some reason this week, a full compilation is not generating a sof output file.
The compiler goes through all the normal stages and shows no errors, but there is no output file.
This is now being seen on 2 separate machines.
Has anyone else seen this? Is there something we can do about it?
Upgrading to a newer version of Quartus is not an option.
Is your license still valid?
Tools->License Setup
Also see this thread
http://www.alteraforum.com/forum/showthread.php?t=4307 (http://www.alteraforum.com/forum/showthread.php?t=4307)
Agreed. License is the first suspect. You can't get a SOF without a license or you may get a time limited sof. Either way, you should get warning messages during compilation.
Jake
