- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello All,
I've just started learning Verilog and as a part of the process i decided to test the testbenches with Verilog PE Student Edition 6.4 . When i compile a verilog file ,it compiles without any error but i have no object file after that! How can i simulate the code? __________________________________________________________________ module stimcrct; reg A,B,C; wire x,y; circuit_with_delay cwd(A,B,C,x,y); initial begin A = 1'b0 ; B = 1'b0 ; C = 1'b0; # 100 A = 1'b1 ; B = 1'b1 ; C = 1'b1; # 100 $finish; end endmodule module circuit_with_delay (A,B,C,x,y); input A,B,C; output x,y; wire e; and# (30) g1(e,A,B); or # (20) g3(x,e,y); not# (10) g2(y,C); endmodule _______________________________________________________________ Please HELP !!! Best Regards링크가 복사됨
5 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- So you are not using QuartusII for your compilation? --- Quote End --- No. I've only started learning Verilog.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
ModelSim has tutorials, they offer an effective way to learn the operation to my opinion.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
When you compile your Verilog design in ModelSim (using the vlog command), it will create a work library that you will need to simulate from using the vsim command.
You can refer to the user guides that came with your installation on how to do this.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Modelsim has a graphical user interface for a lot of things but I prefer using script files like this:
vlib work vlog ../hdl/file1.v vlog ../hdl/file2.v ... vsim -L <library_name> -do wave_all.do work.top log -r /* run -all whereas wave_all.do is the wave file generated with the waveform view. The script is then run from the ModelSim console with do <scriptfilename>, i.e. do test_all.do
