17255 Discussions
ModelSim SystemVerilog compile error
Folks,
I am unable to make sense of an error I get while using ModelSim.
My SystemVerilog module is:
///////////////////BEGIN MODULE/////////////////////////////
module op_transform(input logic[31:0] data, output y);
typedef struct packed {
logic[11:0] op1;
logic[11:0] op2;
} op_str;
op_str my_op_str = 24'hBE_EE_FE;
always_comb begin
if (data > 1024)
opTF(data, my_op_str.op1, my_op_str.op2);
end
task automatic opTF(input logic[31:0] data, ref logic[11:0] opA, ref logic[11:0] op ) ;
/* Code omitted for brevity */
endtask
endmodule
///////////////////END MODULE/////////////////////////////
Quartus Analysis & Synthesis completes without errors.
But when I attempt to compile this in ModelSim, I get the following errors:# ** Error: <filename>.sv(12): The select "my_op_str.op1" into a packed value is illegal for use with ref argument "opA".# ** Error: <filename>.sv(12): The select "my_op_str.op2" into a packed value is illegal for use with ref argument "opB".
Has anybody seen this before?
If I individually list the members of the struct in the module, ModelSim compiles fine. What am I missing?
Any help would be appreciated. Thanks in advance!
You need to use output or inout instead of ref arguments. Passing a ref argument requires a whole variable, not a part select, which is considered an expression.
About the only time you need to use ref arguments is when you have a time-consuming task and you need updated argument values as the task call progresses.
Since this task call is from an always_comb block, opTF really should be a void function. A function call has a guarantee that it will not consume time (has no blocking delays).
Thanks, that's what I figured. An inout did just fine, although there is a copy before and after making the call.
Your suggestion to make opTF a function is good.
Its strange that Quartus does not complain during Analysis & Synthesis but ModelSim does during compilation.
Thanks!
