17267 讨论
ModelSim and filename length limit
名誉分销商 II
4,887 次查看
I'm currently trying to simulate the Hard memory controller example, and the files in "vhdl/submodules" are very long. For some reason modelsim fails to read any of the files with filenames greater than 83 characters !?? I'm running Quartus/modelsim under Windows XP 64 bit, a work colleague has Windows 7 64 bit, and modelsim has no problems reading the same files !
Any help would be much appreciated
Lee
0 项奖励
9 回复数
名誉分销商 II
3,019 次查看
put your project into a subfolder directly over a HDD for example D:\ms
0 项奖励
名誉分销商 II
3,019 次查看
--- Quote Start ---
put your project into a subfolder directly over a HDD for example D:\ms\
--- Quote End ---
Hi, just tried that, still the same.
Lee
0 项奖励
名誉分销商 II
3,019 次查看
Transcript is :-
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Compiling entity ddr_uniphy_hc_example_sim_e0_if0_id_router
# -- Compiling architecture RTL of ddr_uniphy_hc_example_sim_e0_if0_id_router
# Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012
# -- Compiling entity ddr_uniphy_hc_example_sim_e0_if0_addr_router
# -- Compiling architecture RTL of ddr_uniphy_hc_example_sim_e0_if0_addr_router
# ** Error: (vcom-7) Failed to open design unit file "./..//submodules/ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator_avalon_universal_slave_0_agent_rdata_fifo.vho" in read mode.
# No such file or directory. (errno = ENOENT)
# ** Error: C:/altera/13.0/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./run.do line 11
# C:/altera/13.0/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom "$QSYS_SIMDIR/submodules/ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator_avalon_universal_slave_0_agent_rdata_fifo.vho" "
# ("eval" body line 42)
# invoked from within
# "com"
# "if {[file exists msim_setup.tcl]} {
# source msim_setup.tcl
# dev_com
# com
# # the "elab_debug" macro avoids optimizations which preserves signals so tha..."
0 项奖励
名誉分销商 II
3,019 次查看
If I shorten "ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator _avalon_universal_slave_0_agent_rdata_fifo.vho" to "ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator _avalon_universal_slave_0_agent_r.vho" (83 characters) it finds it !
0 项奖励
名誉分销商 II
3,019 次查看
Windows XP has a limit on the total pathname length of 250 chars, not on the filename length. The pathname includes the starting "C:\" and null and the end of the path.
0 项奖励
名誉分销商 II
3,019 次查看
--- Quote Start ---
--- Quote End ---
Thanks to both you (dave_59) and Taz1984, I forgot to rename the vho file back to its original name, after doing this all files are now found if I move the sim project to say c:\ms\ to minimise total pathname length :-)
Many Thanks
Lee
0 项奖励
名誉分销商 II
3,019 次查看
0 项奖励
名誉分销商 II
3,019 次查看
Thanks, made interesting reading, same problem I had, I also can't believe the filenames have to be so long either !
0 项奖励
名誉分销商 II
3,019 次查看
Yep, not only did they leave their brains at home on the day that they created those long filenames but there was an astonishing lack of testing.
0 项奖励
回复
