17265 Discussions
ModelSim reports type mismatch in SOPC Builder generated Code
I have a problem simulating my SOPC builder generated system. If I compile my design in ModelSim SE 6.5b I get the following errors:
--- Quote Start ---
# ** Error: C:/Workspace/BB_CMMB/cmmb_remux.vhd(15323): (vopt-1133) Type mismatch for port "slave_address" in component "clock_crossing_0" when binding to entity "clock_crossing_0".# ** Error: C:/Workspace/BB_CMMB/cmmb_remux.vhd(15323): (vopt-1133) Type mismatch for port "slave_nativeaddress" in component "clock_crossing_0" when binding to entity "clock_crossing_0".# ** Error: C:/Workspace/BB_CMMB/cmmb_remux.vhd(15323): (vopt-1133) Type mismatch for port "master_nativeaddress" in component "clock_crossing_0" when binding to entity "clock_crossing_0".# ** Error: C:/Workspace/BB_CMMB/clock_crossing_0.vhd(275): Vopt Compiler exiting
--- Quote End ---
The corresponding code is the following
--the_clock_crossing_0, which is an e_ptf_instance the_clock_crossing_0 : clock_crossing_0 port map( ... master_nativeaddress(0) => clock_crossing_0_m1_nativeaddress, ... slave_address(0) => clock_crossing_0_s1_address, ... slave_nativeaddress(0) => clock_crossing_0_s1_nativeaddress, ... );with the following port/signal definitions
... signal clock_crossing_0_m1_nativeaddress : STD_LOGIC; ... signal clock_crossing_0_s1_address : STD_LOGIC; ... signal clock_crossing_0_s1_nativeaddress : STD_LOGIC; ...and
component clock_crossing_0 is port ( -- inputs: ... signal slave_address : IN STD_LOGIC_VECTOR (0 DOWNTO 0); ... signal slave_nativeaddress : IN STD_LOGIC_VECTOR (0 DOWNTO 0); ... -- outputs: ... signal master_nativeaddress : OUT STD_LOGIC_VECTOR (0 DOWNTO 0); ... ); end component clock_crossing_0;I dont have problems compiling the design with Quartus II 9.1SP1. So the only workaround I see is to compile it in Quartus II and use the generated *.vho in ModelSim.
Any other suggestions ?
Thanks in advance
try turning off vopt, as i recall there are some incompatibilities with Quartus II and ModelSim 6.5+.
Yeah, this was my first though, but then I get a similar error (the types are incompatible anyway) I'm not in the office anymore, so I cant copy the error message, but I think it was vsim telling me the types are incompatible.
I have another approach now, since it's working if I start the functinal simulation as native link from Quartus II. If I find the error I'll tell you tomorrow, anyway I would appreciate if somebody already knows what I have to do to solve the problem..
With option -novopt I get the following error:
--- Quote Start ---
# Fatal error in Architecture europa at C:/Workspace/BB_CMMB/clock_crossing_0.vhd line 442# while elaborating region: /cmmb_remux/the_clock_crossing_0# Load interrupted
--- Quote End ---
I really dont know how to get rid of this error except fix the error manually in the file. But this can't be the solution ..
can you file a bug report in an SR?
Okay, just submitted the SR.
The only workaround I found was to add an address to the slave interface which is connected through the clock crossing bridge to the NIOS.
The altera support told me that this will be corrected soon.
Till it's fixed I suggest the described workaround if somebody is dealing with the same problem.
