17258 Discussions
Modelsim 10.3d tab size?
I want to change the tab size but I can't find the setting. Google search yielded a couple of options: thru preferences or edit modelsim.ini but they don't seem to work in this version. Any info is appreciated.
Mind elaborate the tab size that you are referring here?
--- Quote Start ---
--- Quote End ---
Sorry. When editing Verilog code and I press tab to indent the code. I think it may be set to 8. I'd like 4 or so.
Hi Rodo,
I believe you can try to ask Altera about if there is any way to customize on this. But I believe you should anticipate that the priority might be low since it is a not a bug or error.
Tools->Edit Preferences->ByName->Source->Tabs
--- Quote Start ---
--- Quote End ---
Awesome!. Interesting how the "Find" button doesn't find it unless I "Expand all" first. Thanks.
--- Quote Start ---
--- Quote End ---
Thanks lot for the sharing.
Nice to learn that we can change the tab size. I have been using space to workaround which is tedious.
