17266 Discussions
Modelsim_AE and Ubuntu 10.1 problem
Hi all!
I've just installed Quartus II 10.1 in Ubuntu 10.1. No problem there. I've also installed ModelSim_AE in Linux, and no problem either.
The problem comes when I want to open ModelSim. I go to the path where I've installed ModelSim and execute Vsim > ./vsim. And it gives the next error:
Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not set correctly. Unable to checkout a license. Vsim is closing. ** Fatal: Invalid license environment. Application closing. I've installed a License, following the steps detailed in http://philpem.me.uk/elec/fpga/quartus-ubuntu/ . Here you can see a screenshot of my license setup:
http://img686.imageshack.us/img686/2677/screenshotxgzb.th.png (http://img686.imageshack.us/i/screenshotxgzb.png/
I've also tried to open ModelSim from Quartus, configuring the path for Modelsim in /opt/Altera/10.1/modelsim_ae/bin (that's where I've installed ModelSim), but when I try to run an RTL Simulation it gives the next error:
http://img571.imageshack.us/img571/5000/screenshot1vtk.th.png (http://img571.imageshack.us/i/screenshot1vtk.png/
Uploaded with imageshack.us (http://imageshack.us
Any suggestion?
Thank you!
ModelSim (even Altera Edition) doesn't use the Quartus II Tools > License Setup license, you must use the LM_LICENSE_FILE environment variable set to the location of the license as indicated in the error
