17267 Discussions
Modelsim ERROR: No extended dataflow license exists
Hi guys i am running a project for some school work on quartus 15.1.
The compilation is ok, test bench is ok, but when i run modelsim appears this error:
# ERROR: No extended dataflow license exists# do Microprocessador_run_msim_rtl_vhdl.do# if {} {# vdel -lib rtl_work -all# }# vlib rtl_work# vmap work rtl_work# Model Technology ModelSim ALTERA vmap 10.4b Lib Mapping Utility 2015.05 May 27 2015# vmap -modelsim_quiet work rtl_work # Modifying /home/altera_lite/15.1/modelsim_ase/linuxaloem/../modelsim.ini
Vhdl files seems ok and i didnt find information about this error. :(
Help would be appreciated.
i didnt found anything about this error.
It seems like Dataflow view is enabled by default in your case, just disable the Dataflow view and you should not see the Error .
You can find it in Modelsim menu View > Dataflow view
arslanusman2003
(This message was posted on behalf of Intel Corporation)
