17267 Discussions
Modelsim: How to change default time unit?
I'd like to change the timeunit for Modelsim. By default Modelsim uses ps, but I'd like to change to ns. Currently if I issue the command run 1000 in the wave window, the time advances 1000ps. I'd like that to run 1000ns.
Where can I define the default time unit to ns?
I have tried changing both the Resolution and UserTimeUnit variables in the modelsim.ini file and neither of those did the trick. Is that setting set somewhere else?
-phil
You must execute:run 1000 ns
See the help for the commands like run, you will learn its syntax and its options ;).
cs1400, thank you for the reply. I know how to use the command line to change the timescale as you described. What I'm asking is, how can I universally and permanently change the time scale so that units are not necessary during run commands?
-phil
you cant afaik.
How about changing the testbench so that it halts iteself, so you can always just type:
run -all
--- Quote Start ---
--- Quote End ---
I have Questasim, but I remember they have the same GUI.
  1. Go to Tools in the toolbar, and Edit Preferences.
  2. Go to the second tab named "By name".
  3. Clic on Exapnd all, then on Find...
  4. Enter the default value of time that your simulator has, check Value in Field, and clic on Find next
You could also see the items
  • Postscript : perpage
  • Compare : defaultLeadUnits and defaultTrailUnits
Basically all defaults are set in the vsim section of modelsim .ini
; vopt flow ; Set to turn on automatic optimization of a design. ; Default is off (pre-6.0 flow without vopt). ; VoptFlow = 1 ; Simulator resolution ; Set to fs, ps, ns, us, ms, or sec with optional prefix of 1, 10, or 100. Resolution = ps ; User time unit for run commands ; Set to default, fs, ps, ns, us, ms, or sec. The default is to use the ; unit specified for Resolution. For example, if Resolution is 100ps, ; then UserTimeUnit defaults to ps. ; Should generally be set to default. UserTimeUnit = default ; Default run length RunLength = 100
--- Quote Start ---
--- Quote End ---
For some reason, changing the Resolution or UserTime Unit to ns doesn't do what I want. Even though those variables are set to ns in my modelsim.ini, and the perferences dialog reports that ns is the chosen unit, when I issue the command run 100, the simulation advance 100 ps, not 100 ns.
-phil
The default settings can be overwritten in the GUI and possibly in a script. Or you are looking to the wrong instance of modelsim.ini.
