17267 Discussions
Modelsim altera error
Hi there,
I have quite a few inout ports on the top module. For them to be output, I have declare them as reg. But these ports give me "Illegal reference to net <..>" when I try to run simulation (compilation runs through with warnings).
Help please.
--- Quote Start ---
Hi there,
Help please.
--- Quote End ---
can you please post your code.
Kind regards
GPK
my bad.. sorry.
I have attached a portion of my code below; while running Modelsim Altera, I get the above error. Basically, based on the 4 bit dap_route code, I either loop-back some ports or route to outside CPLD (Max II).
module top_v (
//DAP1
inout wire dap1_fs,
inout wire dap1_sclk,
input dap1_dout, //input w.r.t CPLD
output wire dap1_din, //output w.r.t CPLD
//DAP2
inout wire dap2_fs,
inout wire dap2_sclk,
input dap2_dout,
output wire dap2_din,
//DAP3
inout wire dap3_fs,
inout wire dap3_sclk,
input dap3_dout,
output wire dap3_din,
input [3:0] dap_route
//Instantiating a module
dap_test_binary dap_call(
//DAP1
.dap1_fs(dap1_fs),
.dap1_sclk(dap1_sclk),
.dap1_dout(dap1_dout), //input w.r.t CPLD
.dap1_din(dap1_din), //output w.r.t CPLD
//DAP2
.dap2_fs(dap2_fs),
.dap2_sclk(dap2_sclk),
.dap2_dout(dap2_dout),
.dap2_din(dap2_din),
//DAP3
.dap3_fs(dap3_fs),
.dap3_sclk(dap3_sclk),
.dap3_dout(dap3_dout),
.dap3_din(dap3_din),
.dap_route(dap_route)
//Actual module
module dap_test_binary (
//DAP1
inout reg dap1_fs,
inout reg dap1_sclk,
output reg dap1_din, //output w.r.t CPLD
//DAP2
inout reg dap2_fs,
inout reg dap2_sclk,
input dap2_dout,
output reg dap2_din,
//DAP3
inout reg dap3_fs,
inout reg dap3_sclk,
input dap3_dout,
output reg dap3_din,
always @ (*)
begin
case (dap_route)
4'b0000: begin //DAP1 (master) looped back to DAP2
dap1_din = dap2_dout;
dap2_din = dap1_dout;
dap2_fs = dap1_fs;
dap2_sclk = dap1_sclk;
end
4'b0001: begin //DAP2 (master) looped back to DAP1
dap1_fs = dap2_fs;
dap1_sclk = dap2_sclk;
end
4'b0010: begin //DAP1 (master) looped back to DAP3
dap1_din = dap3_dout;
dap3_din = dap1_dout;
dap3_fs = dap1_fs;
dap3_sclk = dap1_sclk;
end
4'b0011: begin //DAP3 (master) looped back to DAP1
dap1_fs = dap3_fs;
dap1_sclk = dap3_sclk;
end
default: begin
dap1_fs = 1'bz;
dap1_sclk = 1'bz;
dap1_din = 1'bz;
dap2_fs = 1'bz;
dap2_sclk = 1'bz;
dap2_din = 1'bz;
dap3_fs = 1'bz;
dap3_sclk = 1'bz;
dap3_din = 1'bz;
end
endcase
end
endmodule
//errors
* Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(41): (vlog-2110) Illegal reference to net "dap2_fs".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(42): (vlog-2110) Illegal reference to net "dap2_sclk".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(4http://www.edaboard.com/images/smilies/icon_cool.gif : (vlog-2110) Illegal reference to net "dap1_fs".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(49): (vlog-2110) Illegal reference to net "dap1_sclk".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(56): (vlog-2110) Illegal reference to net "dap3_fs".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(57): (vlog-2110) Illegal reference to net "dap3_sclk".
Thanks for your help.
regards
--- Quote Start ---
my bad.. sorry.
module top_v (
//DAP1
inout wire dap1_fs,
//DAP2
inout wire dap2_fs,
input dap2_dout,
//DAP3
inout wire dap3_fs,
input dap3_dout,
//DAP1
.dap1_fs(dap1_fs),
//DAP2
.dap2_fs(dap2_fs),
//DAP3
.dap3_fs(dap3_fs),
//Actual module
//DAP1
inout reg dap1_fs,
//DAP2
inout reg dap2_fs,
input dap2_dout,
//DAP3
inout reg dap3_fs,
input dap3_dout,
always @ (*)
begin
case (dap_route)
dap2_fs = dap1_fs;
end
dap1_fs = dap2_fs;
end
dap3_fs = dap1_fs;
end
dap1_fs = dap3_fs;
end
default: begin
dap1_fs = 1'bz;
dap1_sclk = 1'bz;
dap1_din = 1'bz;
dap2_fs = 1'bz;
dap2_sclk = 1'bz;
dap2_din = 1'bz;
dap3_fs = 1'bz;
dap3_sclk = 1'bz;
dap3_din = 1'bz;
end
endcase
end
endmodule
//errors
regards
--- Quote End ---
sorry I did not saw it is Modelsim related. At least Quartus could compile the code without an error. I will test the code with modelsim now.
Kind regards
GPK
Looks like it might be an issue with my flawed implementation of bidirectional ports. Help would be appreciated.
