Hi there,
I have quite a few inout ports on the top module. For them to be output, I have declare them as reg. But these ports give me "Illegal reference to net <..>" when I try to run simulation (compilation runs through with warnings). Help please.Link Copied
--- Quote Start --- Hi there, I have quite a few inout ports on the top module. For them to be output, I have declare them as reg. But these ports give me "Illegal reference to net <..>" when I try to run simulation (compilation runs through with warnings). Help please. --- Quote End --- Hi, can you please post your code. Kind regards GPK
my bad.. sorry.
I have attached a portion of my code below; while running Modelsim Altera, I get the above error. Basically, based on the 4 bit dap_route code, I either loop-back some ports or route to outside CPLD (Max II). module top_v ( //DAP1 inout wire dap1_fs, inout wire dap1_sclk, input dap1_dout, //input w.r.t CPLD output wire dap1_din, //output w.r.t CPLD //DAP2 inout wire dap2_fs, inout wire dap2_sclk, input dap2_dout, output wire dap2_din, //DAP3 inout wire dap3_fs, inout wire dap3_sclk, input dap3_dout, output wire dap3_din, input [3:0] dap_route ); //Instantiating a module dap_test_binary dap_call( //DAP1 .dap1_fs(dap1_fs), .dap1_sclk(dap1_sclk), .dap1_dout(dap1_dout), //input w.r.t CPLD .dap1_din(dap1_din), //output w.r.t CPLD //DAP2 .dap2_fs(dap2_fs), .dap2_sclk(dap2_sclk), .dap2_dout(dap2_dout), .dap2_din(dap2_din), //DAP3 .dap3_fs(dap3_fs), .dap3_sclk(dap3_sclk), .dap3_dout(dap3_dout), .dap3_din(dap3_din), .dap_route(dap_route) ); //Actual module module dap_test_binary ( //DAP1 inout reg dap1_fs, inout reg dap1_sclk, input dap1_dout, //input w.r.t CPLD output reg dap1_din, //output w.r.t CPLD //DAP2 inout reg dap2_fs, inout reg dap2_sclk, input dap2_dout, output reg dap2_din, //DAP3 inout reg dap3_fs, inout reg dap3_sclk, input dap3_dout, output reg dap3_din, input [3:0] dap_route ); always @ (*) begin case (dap_route) 4'b0000: begin //DAP1 (master) looped back to DAP2 dap1_din = dap2_dout; dap2_din = dap1_dout; dap2_fs = dap1_fs; dap2_sclk = dap1_sclk; end 4'b0001: begin //DAP2 (master) looped back to DAP1 dap1_din = dap2_dout; dap2_din = dap1_dout; dap1_fs = dap2_fs; dap1_sclk = dap2_sclk; end 4'b0010: begin //DAP1 (master) looped back to DAP3 dap1_din = dap3_dout; dap3_din = dap1_dout; dap3_fs = dap1_fs; dap3_sclk = dap1_sclk; end 4'b0011: begin //DAP3 (master) looped back to DAP1 dap1_din = dap3_dout; dap3_din = dap1_dout; dap1_fs = dap3_fs; dap1_sclk = dap3_sclk; end default: begin dap1_fs = 1'bz; dap1_sclk = 1'bz; dap1_din = 1'bz; dap2_fs = 1'bz; dap2_sclk = 1'bz; dap2_din = 1'bz; dap3_fs = 1'bz; dap3_sclk = 1'bz; dap3_din = 1'bz; end endcase end endmodule //errors * Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(41): (vlog-2110) Illegal reference to net "dap2_fs".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(42): (vlog-2110) Illegal reference to net "dap2_sclk".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(4http://www.edaboard.com/images/smilies/icon_cool.gif : (vlog-2110) Illegal reference to net "dap1_fs".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(49): (vlog-2110) Illegal reference to net "dap1_sclk".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(56): (vlog-2110) Illegal reference to net "dap3_fs".# ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(57): (vlog-2110) Illegal reference to net "dap3_sclk". Thanks for your help. regards- Mark as New
--- Quote Start --- my bad.. sorry. I have attached a portion of my code below; while running Modelsim Altera, I get the above error. Basically, based on the 4 bit dap_route code, I either loop-back some ports or route to outside CPLD (Max II). module top_v ( //DAP1 inout wire dap1_fs, inout wire dap1_sclk, input dap1_dout, //input w.r.t CPLD output wire dap1_din, //output w.r.t CPLD //DAP2 inout wire dap2_fs, inout wire dap2_sclk, input dap2_dout, output wire dap2_din, //DAP3 inout wire dap3_fs, inout wire dap3_sclk, input dap3_dout, output wire dap3_din, input [3:0] dap_route ); //Instantiating a module dap_test_binary dap_call( //DAP1 .dap1_fs(dap1_fs), .dap1_sclk(dap1_sclk), .dap1_dout(dap1_dout), //input w.r.t CPLD .dap1_din(dap1_din), //output w.r.t CPLD //DAP2 .dap2_fs(dap2_fs), .dap2_sclk(dap2_sclk), .dap2_dout(dap2_dout), .dap2_din(dap2_din), //DAP3 .dap3_fs(dap3_fs), .dap3_sclk(dap3_sclk), .dap3_dout(dap3_dout), .dap3_din(dap3_din), .dap_route(dap_route) ); //Actual module module dap_test_binary ( //DAP1 inout reg dap1_fs, inout reg dap1_sclk, input dap1_dout, //input w.r.t CPLD output reg dap1_din, //output w.r.t CPLD //DAP2 inout reg dap2_fs, inout reg dap2_sclk, input dap2_dout, output reg dap2_din, //DAP3 inout reg dap3_fs, inout reg dap3_sclk, input dap3_dout, output reg dap3_din, input [3:0] dap_route ); always @ (*) begin case (dap_route) 4'b0000: begin //DAP1 (master) looped back to DAP2 dap1_din = dap2_dout; dap2_din = dap1_dout; dap2_fs = dap1_fs; dap2_sclk = dap1_sclk; end 4'b0001: begin //DAP2 (master) looped back to DAP1 dap1_din = dap2_dout; dap2_din = dap1_dout; dap1_fs = dap2_fs; dap1_sclk = dap2_sclk; end 4'b0010: begin //DAP1 (master) looped back to DAP3 dap1_din = dap3_dout; dap3_din = dap1_dout; dap3_fs = dap1_fs; dap3_sclk = dap1_sclk; end 4'b0011: begin //DAP3 (master) looped back to DAP1 dap1_din = dap3_dout; dap3_din = dap1_dout; dap1_fs = dap3_fs; dap1_sclk = dap3_sclk; end default: begin dap1_fs = 1'bz; dap1_sclk = 1'bz; dap1_din = 1'bz; dap2_fs = 1'bz; dap2_sclk = 1'bz; dap2_din = 1'bz; dap3_fs = 1'bz; dap3_sclk = 1'bz; dap3_din = 1'bz; end endcase end endmodule //errors * Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(41): (vlog-2110) Illegal reference to net "dap2_fs". # ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(42): (vlog-2110) Illegal reference to net "dap2_sclk". # ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(4http://www.edaboard.com/images/smilies/icon_cool.gif : (vlog-2110) Illegal reference to net "dap1_fs". # ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(49): (vlog-2110) Illegal reference to net "dap1_sclk". # ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(56): (vlog-2110) Illegal reference to net "dap3_fs". # ** Error: C:/Verilog_stuff/Projects/MMSE/E1888/dap_test_binary.v(57): (vlog-2110) Illegal reference to net "dap3_sclk". Thanks for your help. regards --- Quote End --- Hi, sorry I did not saw it is Modelsim related. At least Quartus could compile the code without an error. I will test the code with modelsim now. Kind regards GPK
Looks like it might be an issue with my flawed implementation of bidirectional ports. Help would be appreciated.
