Dear Sir
I want to simulation with modelsim. I used megafunction sqrt, when I compile it's ok but when I run it, it will show the component "sqrt" are not bound. How can I fix it now? Thank in advanceLink Copied
make sure you have the lpm and altera_mf libraries mapped in modelsim.
--- Quote Start --- make sure you have the lpm and altera_mf libraries mapped in modelsim. --- Quote End --- I already have lpm library mapped to modelsim. (220model.vhd and 220pack.vhd) Which is altera_mf library? Can you explain for me. Thank you very much
Sorry. Because I saw a lot of file (altea_mf.vhd, altera_mf_87.vhd and altera_mf_component.vhd) Three of them also have sqrt function. I don't know which one should be used.
you need the whole library, not just one or two files.
Topic Options
