17255 Discussions
Modelsim and sqrt function
Dear Sir
I want to simulation with modelsim. I used megafunction sqrt, when I compile it's ok but when I run it, it will show the component "sqrt" are not bound. How can I fix it now?
Thank in advance
make sure you have the lpm and altera_mf libraries mapped in modelsim.
--- Quote Start ---
--- Quote End ---
I already have lpm library mapped to modelsim. (220model.vhd and 220pack.vhd)
Which is altera_mf library? Can you explain for me. Thank you very much
Sorry. Because I saw a lot of file (altea_mf.vhd, altera_mf_87.vhd and altera_mf_component.vhd) Three of them also have sqrt function. I don't know which one should be used.
you need the whole library, not just one or two files.
