17253 Discussions
Modelsim error "Fatal error in Process MEMORY at c:/intelfpga/21.1/quartus/eda/sim_lib/altera_mf.vhd
t_alars
I am facing an error in Modelsim that I am not able to track it at all.
The error is
It is really confused me. I have the file "cpci_header.hex" and I have putted it in the all possible paths but still the same error. I don't know where should I put it.
Also, where is this path
Am I missing something? I tried to find a clear details about the error or where is my mistake but nothing useful.
I hope someone can answer me.
SyafieqS
Have you tried to delete the db folder recompile and rerun simulation?
Make sure the hex file is at the right path.
t_alars
Hello @SyafieqS
This is the issue, it is no saying where is this path so, I can copy the .hex file to it.
As in the photo, no specific path mentioned in my PC.
SyafieqS
Hi Taha,
Do you mind to post the error message it here? log or txt file containing the error message?
For further analysis
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
