17268 Discussions
Modelsim hanging trying to compile Stratix IP
Hi folks, I'm in the process of migrating a design from Quartus 16.1 targeting an Arria 10 to Quartus 18.0 targeting a Stratix 10. Trying to port one of the testbenches that uses the hard floating point IP, modelsim is hanging when doing the following:
# vlog -reportprogress 300 -sv c:/intelfpga_pro/18.0/quartus/eda/sim_lib/mentor/fourteennm_atoms_ncrypt.sv -work fourteennm_ver
This appears to be from about three quarters of the way through the "dev_com" step from the generated msim_setup.tcl file. Anyone have any ideas what might be causing it and/or what I need to kick to get it to compile?
Andy
Update: it's nothing to do with the over-all IP compilation process, the bug is only with compiling fourteennm_atoms_ncrypt.sv. The same hanging behavior occurs when only trying to compile this one file.
If your project is compiled and generated using Quartus 16.1 than you may face such issue when trying to simulate using other versions of ModelSim.
Means we have to use the appropriate version of ModelSim w.r.t Quartus version.
Hope you are compiling you design and using ModelSim 10.6c with Quartus 18.
Can you share the project files?
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
There's not any relevant project files to share. Just opening modelsim (10.6c) and entering "vlog -reportprogress 300 -sv c:/intelfpga_pro/18.0/quartus/eda/sim_lib/mentor/fourteennm_atoms_ncrypt.sv -work fourteennm_ver" causes modelsim to get stuck and not print anything more (although it doesn't seem to actually crash...)
Further update - the problem actually seems to exist for all of the files with "ncrypt" in the name that the dev_com function wants to try and compile. Also, I just realized I never said but this is running on Windows 10, just in case that makes the slightest difference...
The other problem files are:
ct1_hssi_atoms_ncrypt.sv
ct1_hip_atoms_ncrypt.sv
Further update - just tried updating to the 18.0.1 patch and still having the same issue...
Andy
I've now resolved this issue with the help of Altera tech support. If anyone else hits this same problem, there is a bug in the generated msim_setup.tcl file (which should get fixed with a patch at some point...) when using the free Modelsim version. To fix the problem, change the line:
return [string match "*ModelSim*Intel FPGA Edition*" [ vsimVersionString ]]
to:
return [string match "*ModelSim*INTEL*FPGA*EDITION*" [ vsimVersionString ]]
This is around line 170 in the file.
Hopefully that'll save someone else some pain!
Andy
MuhammadAr_U_Intel
This issue is tracked under knowledge base article.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2018/why-does-modelsim--intel--fpga-starter-edition-re-compiles-devic.html
"This problem is fixed beginning with the Intel Quartus Prime Pro Edition software version 18.1"
