17267 Discussions
Modelsim installation on Ubuntu 18.4 erros
CZhan11
error message: "./vish: error while loading shared libraries: libXext.so.6: cannot open shared object file: No such file or directory"
Has already installed libxft-dev, libxft2, lib32ncurses5.
Abe
Valued Contributor II
You will need to install the missing libraries in Linux for ModelSim to work. Type the following command at the Terminal window prompt.
sudo apt-get install libxtst6
msanyoto
on ubuntu 16.04, 64bit system. I do the following.
sudo apt-get install libxext6:i386
and it's work.
