17259 Discussions
Modelsim is not simulating.
EEren
I have a module I want to test
out_control.vhd
entity OUT_CONTROL is
port
    CLK : in  std_logic;
    RST : in  std_logic;
    OUT_MASK   : in std_logic_vector(55 downto 0);
    OUT_ON_OFF : in std_logic_vector(55 downto 0);
    OUT_TRIG   : in std_logic;
    OUTPUTS    : out std_logic_vector(55 downto 0)
end entity OUT_CONTROL;
architecture behavior of OUT_CONTROL is
type OutStateType is (ST_IDLE, ST_SET);
signal OutState : OutStateType := ST_IDLE;
begin
process(CLK)
begin
    if (rising_edge(CLK)) then
        case OutState is
            when ST_IDLE =>
		if (OUT_TRIG = '1') then
		    OutState <= ST_SET;
		end if;
            when ST_SET =>
                for i in 0 to 55 loop
		    if (OUT_MASK(i) = '1') then
		        OUTPUTS(i) <= OUT_ON_OFF(i);
		    end if;
	        end loop;
	        OutState <= ST_IDLE;
	    when others => OutState <= ST_IDLE;
        end case;
    end if;
end process;
end behavior;
And a test bench
out_control_tb.vhd
entity out_control_tb is
end entity;
architecture test of out_control_tb is
component OUT_CONTROL is
port
    CLK : in  std_logic;
    RST : in  std_logic;
end component;
signal reset : std_logic := '0';
signal clock : std_logic;
signal s_out_mask : std_logic_vector(55 downto 0);
signal s_on_off   : std_logic_vector(55 downto 0);
signal s_outputs  : std_logic_vector(55 downto 0);
signal s_out_trig : std_logic;
signal stop : boolean;
begin
U_OUT_CONTROL : OUT_CONTROL
port map
   CLK => clock,
   RST => reset,
   OUT_MASK => s_out_mask,
   OUT_ON_OFF => s_on_off,
   OUT_TRIG => s_out_trig,
    OUTPUTS => s_outputs
clkgen : process
begin
  while true loop
    clock <= '0';
    wait for 10 ns;
    clock <= '1';
    wait for 10 ns;
  end loop;
  wait;
end process;
process
begin
    if (rising_edge(clock)) then
        wait for 100 ns;
        s_out_mask <= X"0000000000000F";
        s_on_off   <= X"0000000000000F";
        s_out_trig <= '1';
        wait for 20 ns;
        s_out_trig <= '0';
        s_on_off   <= X"00000000000003";
        s_out_trig <= '1';
        wait for 20 ns;
        s_out_trig <= '0';
        wait;
    end if;
end process;
end architecture;
Now I do
1. open a new project in Modelsim
2. add files out_control.vhd and out_control_tb.vhd
3. compile files successfully
4. Simulation -> Start Simulation -> select work/out_control_tb.vhd
5. Add signals to a Wave view.
6. Press Run ( Run continuous) button.
I see
VSIM 23>run (VSIM 24>run - continue)
And nothing. No signals appear on the Wave tab.
What do I do wrong?
sstrell
I think you have to say run -all to advance the simulation.
YEan
Hi there,
Do you have any update on your problem?
Thank you
Ean
EEren
Well...Some problems I resolved another pop up.
For example
process
begin
    reset <= '1';
    wait for 100 ns;
    reset <= '0';
    wait until s_send_rdy = '1';
    s_send_data <= X"88";
    s_send_trig <= '1';
    wait for 40 ns;
    s_send_trig <= '0';
    wait until s_send_rdy = '0';
    s_send_data <= X"ED";
    s_send_trig <= '1';
    wait for 40 ns;
    s_send_trig <= '0';
    wait;
end process;
And I see
Is wait until working directive?
YEan
What does that mean working directive?
sstrell
wait until doesn't exist in Verilog.  Quick Google search for a replacement:
https://stackoverflow.com/questions/12370324/verilog-equivalent-of-wait-until-for
EEren
Who is talking about Verilog ???!!!
Where do you see a single line of Verilog in my code ???!!!
Jesus Christ!!! Unbelievable!!!
