17197 Discussions
Modification programme pour EPLD EPM7128SLC84 Code réalisé avec Quartus 9.0 Osp2 Web Edition (Windows XP)
AMala11
Quelle version Quartus faut -il utiliser (pour utiliser avec Windows 10)?
Novice en programmation EPLD que faut-il installer pour réaliser la modification ?
merci
Vicky1
Here, for compiling & programming(MAX 7000) the EPLD EPM7128SLC84 you can install any Quartus version from 10.1 to 13.0 Web Edition as shown below,
please refer the links below,
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
https://www.intel.com/content/www/us/en/programmable/downloads/software/service-packs/sps-web.html#90
Vicky
AMala11
En pièce jointe mon code Pouvez vous me dire quel est le langage de programmation ? Merci Le lun. 18 nov. 2019 à 09:30, Intel Forums <supportreplies@intel.com> a écrit :
Vicky1
There is no code attached here, but you can identify the language with file extension like below,
VHDL: .vhd
Verilog: .v
System verilog: .sv
Other programming languages like .c & .cpp etc.
Vicky
AMala11
HI Mon code, Pour vous c'est quoi comme langage ? Merci Le mar. 19 nov. 2019 à 03:35, Intel Forums <supportreplies@intel.com> a écrit :
Vicky1
As mentioned in previous post, please identify your language with file extension if you have downloaded it from somewhere otherwise without code it is difficult to support. I request you, please provide screenshot, word file of screenshots or project file(Project menu-> Archive project) *.qar.
Vicky
AMala11
My code
ak6dn
Valued Contributor III
From the .qsf file in the .zip file: set_global_assignment -name AHDL_FILE surveillance.tdf
So the input source file is written in AHDL.
Is this even supported in any recent version of Quartus? The OP it appears is using MaxPlusII v9.0
Vicky1
Yes, It`s written in AHDL & AHDL still supported in latest versions of Intel Quartus tool.
please refer the links below for more details,
https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/reference/glossary/def_tdf.htm
https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/reference/glossary/def_inc.htm
Now I would like to suggest, please open new thread for any query for better support & tracking.
Vicky
ak6dn
Ok, but the last version of Quartus that supports the EPM7128S series parts is 13.0sp1
