Module parameters
Hi.
I'm trying to create a module which has some parameters passed to it.
This is the way I declare the module:
module AAA#(
parameter X= 11,
parameter Y= 9
some of the input / output wires depand on these parameters.
When testing the code, I get an error: "Too many inharited module instance parameters".
I do not have access to the test bench code.
I would appreciate any help or comments.
A useful page to help you get to grips with passing parameters:
http://www.asic-world.com/verilog/para_modules1.html (http://www.asic-world.com/verilog/para_modules1.html)
