NativeLink - Minor Bug?
I think I found a minor bug in QuartusII/NativeLink/ModelSim.
I'm using the following settings to compile and send my testbench to ModelSim:
http://i42.tinypic.com/20pvp21.jpg
However, because there are spaces in my pathing, the "script to set up simulation" fails to execute:
http://i42.tinypic.com/4szls4.jpg
The proper macro call should be enclosed in braces like so:
do {C:/Documents and Settings/Chris Zeh/My Documents/Personal/DE0-Nano/CDC_Toggle/simulation/modelsim/wave.do
It seems that the \simulation\modelsim\<ProjectName>_msim_rtl_verilog.do needs a minor adjustment when it is being generated.
(Or possibly I need an adjustment in where i store my files :))
Currently I'm running Quartus 32-bit Version 11.1 Build 173 11/01/2011 SJ Web Edition
ModelSim ASE 10.0c, Revision 2011.09
you're bound to run into more than just this problem using paths with spaces
True. But it's 2012, I think we should have spaces in paths figured out by now ;)
