Need help fixing errors!
Error (1): VHDL syntax error at Test.vhd(46) near text "WITH"; expecting "end", or "(", or an identifier ("with" is a reserved keyword), or a sequential statement
Error (2): VHDL syntax error at Test.vhd(47) near text "WHEN"; expecting ";"
Error (3): VHDL syntax error at Test.vhd(65) near text "WITH"; expecting "end", or "(", or an identifier ("with" is a reserved keyword), or a sequential statement
Error (4): VHDL syntax error at Test.vhd(66) near text "WHEN"; expecting ";"
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.all;
USE IEEE.STD_LOGIC_ARITH.all;
USE IEEE.STD_LOGIC_UNSIGNED.all;
ENTITY Test IS
PORT(
SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
CLOCK : IN STD_LOGIC;
RESET : IN STD_LOGIC;
LOCKIN : IN STD_LOGIC;
LED : OUT STD_LOGIC_VECTOR(1 DOWNTO 0)
END Test;
ARCHITECTURE a OF Test IS
TYPE STATE_TYPE IS (
RESET_GAME,
XTURN,
XCHECK,
XWIN,
OTURN,
OCHECK,
OWIN
SIGNAL STATE : STATE_TYPE;
SIGNAL SWX : STD_LOGIC_VECTOR(8 DOWNTO 0);
SIGNAL SWO : STD_LOGIC_VECTOR(8 DOWNTO 0);
BEGIN
SWX <= (SW(8) & SW(7) & SW(6) & SW(5) & SW(4) & SW(3) & SW(2) & SW(1) & SW(0));
SWO <= (SW(17) & SW(16) & SW(15) & SW(14) & SW(13) & SW(12) & SW(11) & SW(10) & SW(9));
PROCESS (STATE,CLOCK,RESET,SWX,SWO)
BEGIN
IF (RESET='1') then
STATE <= RESET_GAME;
ELSIF (RISING_EDGE(CLOCK)) then
CASE state IS
WHEN RESET_GAME =>
LED(0) <= '0';
LED(1) <= '0';
WHEN XTURN =>
IF (LOCKIN='1') THEN
STATE <= XCHECK;
ELSE
STATE <= XTURN;
END IF;
WHEN XCHECK =>
WITH SWX SELECT <-------error 1 here
STATE <= XWIN WHEN SWX="000000111", <-------error 2 here
XWIN WHEN SWX="000111000",
XWIN WHEN SWX="111000000",
XWIN WHEN SWX="001001001",
XWIN WHEN SWX="010010010",
XWIN WHEN SWX="100100100",
XWIN WHEN SWX="100010001",
XWIN WHEN SWX="001010100",
OTURN WHEN OTHERS;
WHEN XWIN =>
LED(1) <= '1';
WHEN Oturn =>
STATE <= OCHECK;
ELSE
STATE <= XTURN;
END IF;
WHEN OCHECK =>
WITH SWO SELECT <-------error 3 here
STATE <= OWIN WHEN SWO="000000111", <-------error 4 here
OWIN WHEN SWO="000111000",
OWIN WHEN SWO="111000000",
OWIN WHEN SWO="001001001",
OWIN WHEN SWO="010010010",
OWIN WHEN SWO="100100100",
OWIN WHEN SWO="100010001",
OWIN WHEN SWO="001010100",
XTURN WHEN OTHERS;
WHEN OWIN =>
LED(0) <= '1';
END CASE;
END IF;
END PROCESS;
END a;
You can only use WITH outside a process. Use CASE instead.
Mark.
