17241 Discussions
Altera University Program IP Cores does not appear in Qsys
I have tried different version of quartus. But even so i can not manage to use Altera's University Program IP cores in Qsys. I run the script called install_altera_upds that i downloaded from Altera website. It puts IP core into my quartus directory. All these cores seems to be in /altera/12.1/quartus/ip/University_Program/ .In that directory if i fire ls command, cores appear so:
altera_up_avalon_clocks
Audio_Video
Communications
license.txt
altera_up_clocks
Bridges
Input_Output
Memory
But none of them are appeared in Qsys. How to use them in Qsys ? Any help is highly appreciated.
Cem
I found it. Qsys project must be locate with requested core.
I also have the same your problem. Please tell me what I should do to solve it?
You need to place your project files in same directory. For instance, if you have /home/cem/Project files then ip cores must be in /home/cem/Project/ip directory.
So what you should do is:
create the 'ip' folder in your project folder.
put ip cores in there
start QSys
cheers,
cem
Thank you for your reply :).
You seem to create a project in Linux. I run Quartus in Window environment and I also solved it. All what I do is to download University Program Installer from Altera and install it. After installing, the University Program automatically appears in Qsys.
