When I try to use the following:
hsm2: alt_inbuf port map( i => hsm_rx_d_p(2), o => my_output); I get an error message about O not being connected, even though "my_output" is declared as being a signal. What is the correct way to get LVDS inputs into a design? I cannot use alt_inbuf_diff, since it is not compatible with Stratix II GX. ThanksLink Copied
