17268 Discussions
Need to tell Quartus to use logic and not RAM for shift registers
I found a couple old threads on this subject, but their solutions aren't working for me. I have a few small (12 bit by 4 or 5 cycles) pipelines in a design, and Quartus (version 13.1 at the moment) keeps dedicating RAM blocks to them.
To isolate the problem, I created this example:
module fpga_tester( input clk, input data_in, output data_out ); wire pipeline_outs ; pipline_helper# (.width(12), .max_delay(4)) data_pipe(.clk, .in(data_in), .out_d(pipeline_outs)); assign data_out = pipeline_outs; endmodule module pipline_helper# ( parameter width = 1, max_delay = 1 )( input clk, input in, output logic out_d ); initial begin for(int n=1; n<=max_delay; n++) out_d = '0; end always @(posedge clk) begin out_d <= in; for(int n=2; n<= max_delay; n++) out_d <= out_d; end endmodule
pipeline_helper is a module that I use in code where I need a lot of shift registers. It has multiple outputs to make it easier to reuse, but this particular code only cares about the output of the last stage.
When I build that code in Quartus, it uses a RAM block. I tried adding "//synthesis keep" to pretty much every line of it, but it still turns into RAM. I also tried going into synthesis settings and changing the maximum allowable number of RAM blocks to 0. The design still turns into RAM.
Am I missing something obvious? Are there any other constraints that would cover this?
http://quartushelp.altera.com/current/mergedprojects/hdl/vlog/vlog_file_dir_ram.htm
Try using:
(* ramstyle = "logic" *) output logic out_d
Thanks, that's working great!
