Cyclone V / MAX 10 ROM
Doing tests I found some unexpected results, same code ( generic Verilog, same project, only changing "device" ) give the following reports. Additionally, the sources show the expected results when simulated on Active-HDL, that means I have a ROM initialized.
Flow Status Successful - Sat Dec 13 10:52:57 2014
Quartus II 64-Bit Version 14.0.2 Build 209 09/17/2014 SJ Web Edition
Family Cyclone V
Device 5CEFA2F23C8
Timing Models Final
Logic utilization (in ALMs) 2,147 / 9,430 ( 23 % )
Total registers 1245
Total pins 99 / 224 ( 44 % )
Total virtual pins 0
total block memory bits 16,384 / 1,802,240 ( < 1 % )
Total DSP Blocks 4 / 25 ( 16 % )
Total HSSI RX PCSs 0
Total HSSI PMA RX Deserializers 0
Total HSSI TX PCSs 0
Total HSSI PMA TX Serializers 0
Total PLLs 1 / 4 ( 25 % )
Total DLLs 0 / 4 ( 0 % )
Flow Status Successful - Sat Dec 13 10:58:57 2014
Family MAX 10 FPGA
Device 10M08DAF484C8GES
Timing Models Advance
Total logic elements 4,816 / 8,064 ( 60 % )
Total combinational functions 4,521 / 8,064 ( 56 % )
Dedicated logic registers 1,280 / 8,064 ( 16 % )
Total registers 1280
Total pins 99 / 250 ( 40 % )
total memory bits 128 / 387,072 ( < 1 % )
Embedded Multiplier 9-bit elements 8 / 48 ( 17 % )
Total PLLs 1 / 2 ( 50 % )
UFM blocks 0 / 1 ( 0 %
The module for ROM nothing special :
module PROM (input clk, input [8:0] adr, output reg [31:0] data);
reg [31:0] mem [511: 0];
initial $readmemh("../prom.mem", mem);
always @(posedge clk) data <= mem[adr];
endmodule
Walter
For the MAX 10 project, try turning on "Enable ERAM Preload" in the Analysis & Synthesis settings.
http://www.altera.com/literature/hb/max-10/ug_m10_memory.pdf
Solved, thank you for help;
