17261 Discussions
Nios II IDE - Variables window format
When I debug a Nios II project the IDE "Variables" window always defaults to Natural data format.
This is very annoying since most of my data is useless when displayed in this way and I need to manually change the format nearly at every breakpoint hit!
So I'm asking if is it possible to default the format to Hexadecimal?
I couldn't find any help or reference to this in the manual.
I do this fon NiosEDS. I think that in NiosIDE is the same:
Window/preferences:
C/C++->Debug:
- Default variable format: The options are: Natural,Hexadecimal,Decimal and Binary.
Perfect.
I assumed it should be in the Run/Debug section: that's why I couldn't find it.
Thank you
