17255 討論
posedge clock delay : Quartus II vs. ModelSim
榮譽貢獻者 II
2,013 檢視
I wish to execute a simple code, which is: to expand a 1-bit signal into a 16-bit signed register. however, the assignment should happen after 1 clock cycle delay.
I wrote the following code, in verilog:
always @ (posedge clock)
begin
Vsw_16bit <= @ (posedge clock) (sw_node) ? (16'sd32767) : (16'sd0);
end
I verified it in ModelSim, it worked correctly. But when I pasted the same code in Quartus II and ran a Funtional simulation, there was simply no delay. The assignment happened at the very first clock edge. Needless to say, even the Timing simulation didn't work.
I changed my code, to the following:
always @ (sw_node)
begin
Vsw_16bit <= repeat (2) @ (posedge clock) (sw_node) ? (16'sd32767) : (16'sd0);
end
Even this code supplied the expected 1 clock cycle delay in ModelSim.
But again, when I checked it in Quartus Functional simualtion, the assignment happened at the very instant my sw_node changed value. It didn't wait for any clock edge this time.
why doesn't quartus wait for any clock edge inside the always statement ? Isn't it a valid Verilog construct ? Moreover, Quartus didn't even show any compilation errors for it.
How are we supposed to delay assignments then ?
0 積分
3 回應
榮譽貢獻者 II
1,154 檢視
It is a valid Verilog construct. But it is not synthesizable.
Do this instead:
always @ (posedge clock) logic local_sw_node; begin local_sw_node <= sw_node; // delay it one clk cycle Vsw_16bit <= (local_sw_node) ? (16'sd32767) : (16'sd0); end
榮譽貢獻者 II
1,154 檢視
thanks amilcar,
So this means, we would require (n-1) intermediate local_registers in order to produce a n-cycle delay. That's fine !
A few more things:
I just started off with verilog coding on my Cyclone 3 starter kit, after going through the my_first_fpga_tutorial
Due to my average programming background, I'm familiar to just 2 terms till date: 'compilation' & 'execution'.
I still don't understand terms like: 'synthesizable'. What do you mean by saying that the 'clock edge delay' is valid but not synthesizable ? If it can't be implemented in an fpga, why was it included as valid in verilog ?
Any document / web-link , where I can easily understand the terms (differences between) : analysis, synthesis, elaboration, compilation, fitting ... and so many other hybrid terms - post-fitting, pre-synthesis, etc, etc.
榮譽貢獻者 II
1,154 檢視
Verilog can be "simulated" (executed by software on a PC) and "synthesized" (to later be executed in hardware by an ASIC or FPGA).
The entire language (Verilog) can be simulated but only a small number of stuff can be synthesized.
> Any document / web-link , where I can easily understand the terms ?
Try doing the altera tutorials. And reading the user manuals.
One last thing. Stay AWAY from Verilog, use SystemVerilog instead. Its better and simpler.
回覆
