OpenCL hello world error
FCive
Dear Community,
I am trying to compile the hello_world.cl program for the Arrow Sockit based on an Intel Cyclone V SoC. I follow this guide (https://rocketboards.org/foswiki/pub/Documentation/ArrowSoCKitOpenCL/SoCkit_OpenCL_Setup-v14.0--2014-11-25.pdf) and I am able to create the .aoco, but when I launch the following command:
aoc -v -board=arrow_c5sockit_sharedmem -report hello_world.cl
I got this output:
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error: Error in adjust_plls.tcl!
Error: Flow compile (for project /home/netfpga/Downloads/examples/HelloWorld/hello_world/device/hello_world/top) was not successful
Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script /home/netfpga/intelFPGA/17.1/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 4 errors, 668 warnings
Error: Compiler Error, not able to generate hardware
The complete log file is attached (quartus_sh_compile.log).
I am using OpenCL SDK 17.1 and Quartus 17.1. The bsp for the Sockit was done with 14.0 version.
Do I have to use 14.0 version for both OpenCL SDK and Quartus? Could you please give me some suggestions?
Thank you.
HRZ
Valued Contributor III
Yes, you likely have to use Quartus and OpenCL SDK v14.0/v15.0 or obtain a newer BSP for your board.
FCive
Thank you for your answer. I will try to find a newer bsp or move the bsp v14.0 to v17.1. Otherwise I will install v14.0 for both OpenCL SDK and Quartus
FCive
Unfortunately, the error persists even with Quartus and OpenCL SDK v14.0.
Any other suggestions?
Thank you
