OpenCL with DE0-nano-SoC
I am trying to get OpenCL going on the DE0-nano-SoC, I've found a linux image that supports OpenCL finally and I am able to run the OpenCL demos shipped with that image, however when I try to run one of my own OpenCL programs I get the following error, so far my best guess is version mismatch in the libraries.
symbol lookup error: /home/root/opencl_arm32_rte/host/arm32/lib/libalteracl.so: undefined symbol: acl_hal_get_system_definition
If I grab the libraries from the shipped image and try to re-compile my host code aginst those I get a similar error:
libalteracl.so: undefined reference to `acl_hal_get_system_definition'
Any Ideas how I can get around this or what's going on?
Similarly, I've been trying to get a custom image running using yocto, however so far I haven't been successful. I can boot and run the `init_opencl` script which successfully inserts the `aclsoc_drv`. however when I try and run my program I get an error that hangs the system requiring a restatr:
root@cyclone5:~# ./run_program Unhandled fault: imprecise external abort (0x406) at 0xbef4be34 pgd = eeeec000 *pgd=2e7f1831, *pte=2df6c75f, *ppte=2df6cc7f Internal error: : 406 SMP ARM Modules linked in: aclsoc_drv(O) CPU: 1 PID: 808 Comm: run_program Tainted: G O 4.3.0-altera# 1 Hardware name: Altera SOCFPGA task: eef18000 ti: ee7e4000 task.ti: ee7e4000 PC is at aclsoc_rw+0x1f8/0x42c LR is at aclsoc_rw+0x1c8/0x42c pc : lr : psr: 200e0013 sp : ee7e5e48 ip : 00004bda fp : ee7e5ec4 r10: 00000001 r9 : 00000002 r8 : eec34000 r7 : 00000008 r6 : 00000000 r5 : f020c870 r4 : f020c870 r3 : 00000000 r2 : c07ca100 r1 : 00000000 r0 : ffffb0bb Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none Control: 10c5387d Table: 2eeec04a DAC: 00000051 Process run_program (pid: 808, stack limit = 0xee7e4218) Stack: (0xee7e5e48 to 0xee7e6000) 5e40: ee7e5e7c 00000001 00000000 00000000 ee7e4000 eed8d634 5e60: 00000000 eec34000 00000000 00000008 00000008 bef4c468 eee77910 00000000 5e80: 00000002 00000000 0000c870 bef4c468 00000008 00000000 ee50e9c0 ee50e9c0 5ea0: bf0010f8 ee7e5f80 00000018 c000fe04 ee7e4000 00000000 ee7e5edc ee7e5ec8 5ec0: bf00111c bf000cd8 00000001 ee9eb5d8 ee7e5f4c ee7e5ee0 c0128bd4 bf001104 5ee0: 00000000 00000000 00000000 ee7e5ef0 eee52300 eed74d40 00000000 c0146730 5f00: 00000001 c01377f8 c07cad34 ee460000 ee50e9c0 c012942c 00000020 eeeac478 5f20: ee50e9c8 c0146a2c bef4c410 ee50e9c0 ee7e5f80 00000018 c000fe04 ee7e4000 5f40: ee7e5f7c ee7e5f50 c0129448 c0128ba4 c0139a14 c01469bc ee50e9c0 ee50e9c0 5f60: bef4c410 00000018 c000fe04 ee7e4000 ee7e5fa4 ee7e5f80 c0129d5c c01293cc 5f80: 00000000 00000000 b5916124 00020658 b619e000 00000003 00000000 ee7e5fa8 5fa0: c000fc40 c0129d14 b5916124 00020658 00000003 bef4c410 00000018 bef4c410 5fc0: b5916124 00020658 b619e000 00000003 0001ff48 b6eeacd0 0001ff88 b619e408 5fe0: 00000000 bef4c3fc b5902865 b56633a0 600e0010 00000003 00000000 00000000 (aclsoc_rw ) from (aclsoc_read+0x24/0x2c ) (aclsoc_read ) from (__vfs_read+0x3c/0xe4) (__vfs_read) from (vfs_read+0x88/0x114) (vfs_read) from (SyS_read+0x54/0xb0) (SyS_read) from (ret_fast_syscall+0x0/0x3c) Code: e3a06000 ea000007 e5943000 f57ff04f (e5883000) ------ aclsoc_close (191): aclsoc = eed8d600, pid = 808, dma_idle = 1
