17268 Discussions
OpenSource OpenCL design of CNNs Accelerator on FPGAs for everyone :)
I have designed an OpenCL-based Accelerator for Convolutional Neural Networks on FPGAs, it can be found on github.com/doonny/PipeCNN.
Currently, AlexNet and VGG-166 models are tested on DE5-net boards.
Hope someone maybe interested to join us to improve the design.
Cheers,
I'm very interested in your work,and thank you for your code, but i can't compile the conv_pipe.cl because I can't find the RTL folder.
--- Quote Start ---
--- Quote End ---
Hi, I found the RTL directory under the project -> device directory.
I did manage to get it to run the AlexNet on a DE10-Standard Board with a total Kernel Run time of 298ms
J
Thanks for providing code.
I am able to run the demo using OpenCV with following o/p for Alexnet:
Loading kernel/binary from file project/conv.aocx
Reprogramming device [0] with handle 1
61063552 total weights read
1024 total output reference read
Loading picture ./data/ILSVRC2012_val_00000001.JPEG .....
Executing Layer 1:
Launching single work-item kernel winbuffer
Launching single work-item kernel Conv
Launching single work-item kernel Pooling
Launching kernel MemWr with local size: 1, 1, 16 (global size: 27, 27, 96)
Launching kernel lrn with local size: 1, 1, 24 (global size: 27, 27, 24)
Executing Layer 2:
Launching kernel MemWr with local size: 1, 1, 16 (global size: 13, 13, 256)
Launching kernel lrn with local size: 1, 1, 64 (global size: 13, 13, 64)
Executing Layer 3:
Launching kernel MemWr with local size: 1, 1, 16 (global size: 13, 13, 384)
Executing Layer 4:
Executing Layer 5:
Launching kernel MemWr with local size: 1, 1, 16 (global size: 6, 6, 256)
Executing Layer 6:
Launching kernel MemWr with local size: 1, 1, 16 (global size: 1, 1, 4096)
Executing Layer 7:
Executing Layer 8:
Launching kernel MemWr with local size: 1, 1, 16 (global size: 1, 1, 1024)
Done! Inference time is 0.045396s
Copied all batched results from fc_2 buffers.
Selected item = 0 from the combined batch results in fc buffers
The inference result is n01737021 water snake (the prob is 37.00)
False: True_label = 970 Inferred_label = 58
Current Top-1 accuracy = 0.000
Current Top-5 accuracy = 1.000
Loading picture ./data/ILSVRC2012_val_00000002.JPEG .....
Done! Inference time is 0.044439s
The inference result is n04228054 ski (the prob is 46.00)
False: True_label = 230 Inferred_label = 795
Loading picture ./data/ILSVRC2012_val_00000003.JPEG .....
Done! Inference time is 0.044546s
The inference result is n02105855 Shetland sheepdog, Shetland sheep dog, Shetland (the prob is 99.00)
Current Top-1 accuracy = 0.333
Loading picture ./data/ILSVRC2012_val_00000004.JPEG .....
Done! Inference time is 0.044284s
The inference result is n07920052 espresso (the prob is 81.00)
False: True_label = 516 Inferred_label = 967
Current Top-1 accuracy = 0.250
Current Top-5 accuracy = 0.750
Loading picture ./data/ILSVRC2012_val_00000005.JPEG .....
Done! Inference time is 0.044279s
The inference result is n03125729 cradle (the prob is 34.00)
Current Top-1 accuracy = 0.400
Current Top-5 accuracy = 0.800
Loading picture ./data/ILSVRC2012_val_00000006.JPEG .....
Done! Inference time is 0.044487s
The inference result is n01755581 diamondback, diamondback rattlesnake, Crotalus adamanteus (the prob is 51.00)
False: True_label = 334 Inferred_label = 67
Current Top-5 accuracy = 0.833
Loading picture ./data/ILSVRC2012_val_00000007.JPEG .....
Done! Inference time is 0.044391s
The inference result is n02346627 porcupine, hedgehog (the prob is 99.00)
Current Top-1 accuracy = 0.429
Current Top-5 accuracy = 0.857
Loading picture ./data/ILSVRC2012_val_00000008.JPEG .....
Done! Inference time is 0.044590s
The inference result is n03063599 coffee mug (the prob is 56.00)
False: True_label = 674 Inferred_label = 504
Current Top-1 accuracy = 0.375
Loading picture ./data/ILSVRC2012_val_00000009.JPEG .....
Done! Inference time is 0.044468s
The inference result is n03201208 dining table, board (the prob is 26.00)
False: True_label = 332 Inferred_label = 532
Current Top-5 accuracy = 0.667
Loading picture ./data/ILSVRC2012_val_00000010.JPEG .....
Done! Inference time is 0.044281s
The inference result is n04399382 teddy, teddy bear (the prob is 36.00)
False: True_label = 0 Inferred_label = 850
Current Top-1 accuracy = 0.300
Current Top-5 accuracy = 0.700
Demo exited !!!
Total number of 10 pictures have been processed.
Final Top-1 accuracy = 0.300
Final Top-5 accuracy = 0.700
Any suggestion to improve the results using any optimization techniques...?
