17247 Discussions
Verilog Warning: No clocks defined in design
I'm using Cyclone IV DE2-115 board, I have tried connecting the CLOCK_50 input to the clocks pin according to this manual ftp://ftp.altera.com/up/pub/altera_material/13.0/boards/de2-115/de2_115_user_manual.pdf. I tried PIN_Y2 (CLOCK_50) as well as PIN_AE23 (SMA_CLKOUT) both this warning still persists. Any help would be greatly appreciated!
module uart( input wire CLOCK_50, // map to onboard clock (50 MHz) input wire i_Rx_Channel, // Rx channel, map to general purpose pin input wire i_Tx_DV, // signals TX to read a byte to send input wire i_Tx_Byte, // byte to be sent by Tx output wire o_Tx_Channel, // Tx channel, mapped to GPIO 1 output wire o_Rx_Ready, output wire received_Rx_byte); // map to onboard LEDs for testing parameter c_CLOCK_PERIOD_NS = 100; parameter c_CLKS_PER_BIT = 434; parameter c_BIT_PERIOD = 8600; uart_rx# ( .CLKS_PER_BIT (c_CLKS_PER_BIT) ) receiver( .i_Clock (CLOCK_50), .i_Rx_Serial (i_Rx_Channel), .o_Rx_DV (o_Rx_Ready), .o_Rx_Byte (received_Rx_byte) ); endmodule
No clocks defined means you didn't create a .sdc file for timing analysis. You need to constrain the design.
But it shouldnt affect whether my code works correct? Thanks!
--- Quote Start ---
--- Quote End ---
